TwinTurbo.NET: Nissan 300ZX forum - Re: Rattle from gear shift (manual trans)
SaphireZ
on August 17, 2012 at 12:38 PM
posted by Mike (Raleigh)
on August 17, 2012 at 11:53 AM
not trying to scare you, but this was a huge indicator that something was wrong in my trans at least for me, mine started making a ton of noise before it went out... just had to spend $1200 to rebuild it.
Mike (Raleigh)
11:53:16 08/17/12
Did you check the shifiter bushings?
Woody75 (Denver)
12:24:23 08/17/12
Re: Did you check the shifiter bushings?
Mike (Raleigh)
12:37:37 08/17/12
Shifter bushing replacement write up is in the TECH section.
Woody75 (Denver)
13:20:58 08/17/12
Sounds like my issue - thanks for the pointer! (n/m)
Mike (Raleigh)
13:47:43 08/17/12
If the bushing fix doesn't work there is also an
jzack
12:22:59 08/18/12
Re: Rattle from gear shift (manual trans) -
SaphireZ
12:38:24 08/17/12
Re: Re: Rattle from gear shift (manual trans)
SaphireZ
12:41:39 08/17/12
